VRRP Transitions
When a VRRP transition takes place with the backup taking over as the master, look for the following message in the syslog on the new master, as well as the old master. This message provides information to allow you to determine the cause of the transition.
IPv6 Vrrp State Transition Trap(Port/Vlan=200, Type=masterToInitialize, Cause=shutdownReceived, VrId=20,VrIpAddr=fe80:0:0:0:0:0:0:200, Addr=fe80:0:0:0:224:7fff:fe9d:1a03)
In this message, see the Type and Cause fields.
Although the possible causes and types are listed in the following table, the system does not display all of the listed causes and types in the trap/log message.
The following table describes the VRRP transition types.
Table 1. Transition type
Type value
Type definition
1
None
2
Master to backup
3
Backup to master
4
Initialize to master
5
Master to initialize
6
Initialize to backup
7
Backup to initialize
8
Backup to backup master
9
Backup master to backup
The following table describes the VRRP transition causes.
Table 2. Transition cause
Cause value
Cause definition
1
None
2
Higher priority advertisement received
3
Shutdown received
4
VRRP address and physical address match
5
Master down interval
6
Preemption
7
Critical IP goes down
8
User disabling VRRP
9
VRRP status synced from primary
10
IPv6 interface on which VRRP is configured goes down
11
Lower priority advertisement received
12
Advertisement received from higher interface IP address with equal priority
13
Advertisement received from lower interface IP address with equal priority
14
User enabled VRRP
15
Transition because of any other cause
